For those of you that have had a hard time getting your ATI AIW 128 pro working correctly, I have some good news. I have been trying for almost a year to resolve the audio/video sync problem that a number of us have been experiencing. I was finally able to demux and re-mux the mpeg2 without the audio sync problem.
The AIW card has to have its own IRQ - even on a fast machine (mine is 1.3ghz w/ 1g ram). In Win2K, the only way to do it is to turn off the ACPI and do a repair installation as a 'Standard PC'. There is an obscure reference at the MS site on how to do this. If I can find it again, I will update this post. This saves hours of processing time. Instead of capturing to avi and encoding, you can encode to mpeg2 and use Tmpgenc to convert to SVCD mpeg2.
Also, you're better off if you don't use onboard sound. Use a separate sound card for the hardware buffering.
Results 1 to 1 of 1
AnonymousGuest
ATI AIW 9800 Pro worst capture card ever?
By veedeo in forum Capturing and VCRReplies: 15Last Post: 1st Jan 2011, 19:41 -
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 12:26 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 06:11 -
ATI AIW X800GT - ANY capture software besides MMC?
By nbarzgar in forum Capturing and VCRReplies: 23Last Post: 18th Nov 2007, 02:24 -
Problems with Pal-60 capture using ATI AIW 2006 PCI express Radion X1300
By DB83 in forum Capturing and VCRReplies: 2Last Post: 6th Aug 2007, 17:49
