Hi Guys!![]()
Now I have got some NTSC recordings that my VCR plays fine, but when I go to copy them to a dvd-r via my Panasonic DMR-E50, it goes all shacky, and if I select NTSC format on the dvd recorder, then the picture is still but it is in Black and White!!!!![]()
This is really starting to annoy me, so please try to help!!!!?
I am a dvd novice, please don't be funny with me! :(
Sounds like you need a TBC and/or a video stabilizer. Go here:
https://www.videohelp.com/forum/viewtopic.php?p=939492&highlight=tbc#939492
Also, DVD Recorder forum here:
https://www.videohelp.com/forum/viewforum.php?f=28 -
Your VCR is NOT outputting a true NTSC signal. It is doing that "quasi" signal that is acceptable to view. Most European PAL equipment can handle NTSC material BUT....it is not converting it to a true NTSC signal which most DVD Recorders(including my Philips) cannot record correctly.
You can change settings on your Panasonic until you are blue in the face and it won't help the problem. The problem lies in the VCR. If your VCR was under $400....it's not "converting" the signal....it's just making it acceptable.
Here is the one I own:
http://shopping.yahoo.com/p_aiwa-hv-mx100_hifi-vcrs_1990375901
I paid a bit less for it however...but not much.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
Copying some home video on VHS to DVD
By syilim in forum Newbie / General discussionsReplies: 1Last Post: 4th Nov 2008, 22:23 -
dvd recorder/vhs copying question
By nobbydadog in forum DVD & Blu-ray RecordersReplies: 6Last Post: 28th Dec 2007, 07:58 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 02:16
