hi all, ive got a movie i downloaded which was an .ogg movie. ive got the correct codecs installed which allow tmpgenc to recognise my video. however, when i try and encode the video the subs dont show up in the mpeg2 file. ive searched this site, but all the topics or guides describe how to add subs to various video formats, all i want to know is how to encode with permanent subs? i'm thinking it might be something to do with Vobsub? the movie came with the subs, there's no extra .sub or .srt file containing the subs btw.
any help/suggestions/comments would be greatly appreciated, thanks.![]()
ogg can have the subs as a selectable stream. The fact that you didn't get any subs when encoding proves this is so in this case. So you have to demux the subs, possibly convert them to some recognized format (or find them elsewhere in some format that you can add) and add them with VirtualDub
/Mats -
so which program could i use to demux the subs? thanks for your help btw.
I think there's some version of VirtualDub that handles more than one video and one audio stream. Look under the Tools section...
/Mats -
https://www.videohelp.com/forum/viewtopic.php?t=222005
here's a guide that shows you have to convert ogm to dvd, including how to add permanent subs. -
the ogg movie already had permanent subs added to it, i just didnt know how 2 demux the subs to create the .ssa format, but dw, i found the subs elsewhere. thanks for the help anyway guys
[/list]
If you can switch subtitles on/off they are not permanent. If you cannot switch them off, then you cannot demux them.
adding permanent subs to mp4
By xtwist3dx in forum Newbie / General discussionsReplies: 15Last Post: 18th Mar 2014, 19:28 -
How to add permanent subs inside a semi-transparent box?
By majin_buu in forum SubtitleReplies: 5Last Post: 9th May 2009, 11:43 -
having trouble adding permanent subs wtih vdubmod
By myname77 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Nov 2008, 09:08 -
Subs & Filters in Tmpgenc DSC
By marioval in forum Authoring (DVD)Replies: 5Last Post: 24th Apr 2008, 10:34 -
Creating my own subs for avi & editing subs of ogm & mkv
By retroborg in forum SubtitleReplies: 1Last Post: 1st Jan 2008, 14:33
