I have tried several options running TMPGEnc but no setting seems to work that displays the dvd correctly. Is there some setting I'm missing ?? or is there another application that can actually rip a 2.35:1 DVD ??
In tmpgenc, in settings->advanced tab
select 16:9 525 ntsc (or the pal eqivilant)
and in video tab select 4:3 525 ntsc (or pal if needed).
this should encode your movie at proper aspect.
Yes, probably the dvd is 16:9 anamorph encoded, not 1:2,35. Also check different video arrange methods. As long as you resize to a smaller frame size (for example 720x576-->480x432), "full screen[keep aspect ratio]" is the one.
PS3 with non-anamorphic DVD
By Pliny in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Jul 2014, 09:10 -
Non-anamorphic 1.66:1 DVD on LCD TVs ?
By Kweldood in forum DVD & Blu-ray PlayersReplies: 20Last Post: 12th Jan 2012, 06:16 -
Is it possible to re-edit a non-anamorphic dvd to anamorphic?
By Beautiful Alone in forum DVD RippingReplies: 45Last Post: 22nd Sep 2011, 09:00 -
Best way to convert 4:3/non-anamorphic DVDs to 16:9 anamorphic. HELP!!
By CoachSerpico in forum Video ConversionReplies: 9Last Post: 11th Feb 2010, 15:46 -
Anamorphic DVD Recorders?
By wulf109 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 6th May 2008, 15:05
