trying to put several episodes on to one dvd with menus.
but when i use TMPGEnc DVD Author and load the first clip i get an gop error . do i have to convert the clip first and if so whats the best program? if i use TMPGEnc to convert to dvd then the file is to big to put more than one on dvd disc .
What format are you converting to ? If you've used a DVD template you shouldn't get the GOP error. I get that error message when I author SxVCDs onto a DVD, they play fine though.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
TMPGEnc Dvd author 3 problem
By prcole18 in forum Authoring (DVD)Replies: 7Last Post: 7th Oct 2008, 12:33 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 20:20 -
TMPGEnc DVD Author 3 - Playback problem, Help!
By cbales_24 in forum Authoring (DVD)Replies: 2Last Post: 18th Oct 2007, 17:29 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 20:43
