Hi I thought I had this sussed and have read a lot of ntsc 2 pal threads but none seamed to answer my problems so i thought I'd start a new one ...
Q. How do you convert a video format to a DVD compliant PAL.
I have been using canopus pro coder and have simply been setting the output to pal, thinking that it would render at the correct rez, correct frame rate, withc it dose... but the problem is that it forces the file to run over the same time span, so the resulting video file is running very fast and way out of sync with the sound.
Is there a CCE front end for converting stuff to DVD compliant PAL? I mean idealy I would like to take all the files I have and run them through them same encoder so they end up all with the same dimentions, frame rates and the like...
Is there any way to do this... I nned to run it on DivX, XviD, Mov, TechSmith and Mpeg files...... but do not stress about the files I can convert them into almost any format, I just need a way to get them all to end up as nice DVD style PAL movies.
Results 1 to 1 of 1
CCE Pal to Ntsc conversion-NO AUDIO
By ranosb in forum Video ConversionReplies: 9Last Post: 2nd May 2009, 05:45 -
FAVC Pal-Ntsc conversion question
By spiritgumm in forum Video ConversionReplies: 4Last Post: 24th Feb 2009, 10:12 -
CCE guide for PAL to NTSC conversion
By alexs_eu in forum Video ConversionReplies: 9Last Post: 21st Jun 2008, 07:41 -
sorry for yet another pal to ntsc conversion question relating high def.
By gearo in forum Video ConversionReplies: 2Last Post: 3rd Nov 2007, 22:20 -
Canopus Pro Coder Problem
By Heineken77 in forum Authoring (DVD)Replies: 10Last Post: 17th Jun 2007, 04:15
