Hey I was just wondering if you burn a double sided DVD can you label one side with like one of the EPSON printers and still have a DVD player read it. Is there anyway you can label a side if you can't with an EPSON printer??
Results 1 to 16 of 16
You would have to label it in the clear part of the hub, not on the data surfaces.
Sounds kinda like my neighbor. The fence in back was falling down, so we got a very reasonable estimate to replace it. He then gives us a very high estimate for him to replace it. We refused, so he says "Fine! I'll just do my side of the fence!"
Like redwudz said, your best bet is a hub label. -
Ive seen people leave the falling down fence and build their fence on their side .
Huh???
You can't build one side of a fence that has two sides. I'm talking about front and back, not left and right. Basically, it's like saying "When you're on my side of the fence, you will see a new fence. On you side, you will see nothing." -
Well you could build a fence next the old crappy one. So the neighbor has a nice new fence while you are left with a crappy one. My neighbor did something similar; they took the old fence down, but they did a crappy job on my side. There was cement and crumbling brick on my side and a nice clean job on the other.
And yah a hub center sticker will do. I have seen some cheap labels that are two parts: complete label from the outside edge to the inside edge with a smaller hub label in the inside. -
They make hub ring that work pretty good. Use them since they dont affect the data area. You get about 26 per sheet.
Why not use a Sharpie and write on the clear hub ring? Seems a waste of time to make that small a lable, hard to see anything on it.
Alternatively, use a "clear" Sharpie, write where you want.
Cheers,
George -
Originally Posted by gmatov
88,
But, you gotta admit it's true.
Hell, I gotta put on my bifocals to read a commercial DVD, 6 point type on a 3/8 wide lable would be damned small.
Cheers,
George -
Originally Posted by gmatovWant my help? Ask here! (not via PM!)
I know! Lets split the difference. Use a Sharpie in a pen ploter and have it write on the disk.
Wells its an ideal.... -
Originally Posted by dimtim
BTW...I'm a proud Sharpie user,you hub labelers are weird.
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 16:13 -
Double-Sided, Dual-Layer DVD media?
By dgpretzel in forum MediaReplies: 22Last Post: 15th Apr 2008, 15:03 -
Double sided discs
By brainoverload in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2008, 10:15 -
Dual-Layer Double-Sided DVD's turnover?
By Deisel Weisel in forum DVD & Blu-ray RecordersReplies: 6Last Post: 22nd Nov 2007, 21:23 -
double sided printing on normal printer
By hamilton accie in forum Off topicReplies: 1Last Post: 6th Jun 2007, 21:09
