I'm just wondering if I should buy a 8 X DVD Burner, what media will write at 8X and work well for movies ?
I got a 4X LG burner already but should I get a 8X LG Burner to, I haven't seen any media that say 8 X on them ?
Thanks for all your help guy's keep up the good work !!!
Results 1 to 10 of 10
I would suggest you take a look at the DVD WRITERS to the left<<<<<<
There postings of comments on different brands of burners. You may want to check the different forum sites at cdfreaks.com, they have forums for PIONEER, PLEXTOR, NEC, LITEON, LG, & BTC. Or check out this link:
http://forum.firmware-flash.com/viewforum.php?f=2
By the way don't buy another used dvd burner. -
it depends...burning faster sometimes makes the disc incompatible with some dvd players cause the pits arent deep enough, and thens theres away the chance of buffer underun when burning fast. that equals a coaster.
also, dont get dual layer. the only DualLayer availible out there are DVD+R, which only works with 88% of the DVD players out there, while DVD-R works with 93%. that small % is all it takes to ruin your hard work. imagine after burning the disc, you find that your dvd player doesnt support it. or you send the disc to family and friends for christmas/whatever, and they cant play it on their standalone cause its a DVD+R. both the PS2 and XBOX do not play DVD+Rs, only DVD-Rs.
the final decision on 8x or not is your choice. -
choirislife923 Wrote:
choirislife923 you quote is not true, for the PS2 it depends on which model you have if it plays +R's or -R's some model's play both(mine play some -R's but loves +R's). The X-Box play's both -R and +R. The % that you are giving is for older Standalone's. A person should have dual burner(sometimes I feel like I dont need both, cause I burn more +R's)both the PS2 and XBOX do not play DVD+Rs, only DVD-Rs. -
You can get an 8x dual format burner with +DL support for under $100 right now.
If you want to go with a hacked firmware, you can get an NEC or Lite On 8x dual format burner that can use a hacked firmware to burn to +DL discs for ~$70-$75.
But......
Since you already have a 4x LG burner, there is no need to replace it with an 8x unit. If you need to add an addition, then go for it. From experience, 8x burning isn't all it's cracked up to be. It isn't a true 8x burn, it starts at 4x, then around 25% switches to 6x, then later on, switches again to 8x. Total burn time is just under 10minutes for a full disc. Also some media will have problems at the speed switches. These problems can be seen on the media itself, and some will cause a stutter/skip in older, less forgiving set top players.
Most drives will write 4x Taiyo Yuden and 4x Verbatim discs at 8x. Carefull with the verbatims, they are made in 3 factories, and each produces different results. Depending on the drive, most other 4x media will burn at either 6x or 4x.
Most drives will write most Ricoh +R discs at either 6x or 8x.
Ritek, Taiyo Yuden, Verbatim, and Maxell make 8x DVD-R media that is widely available. Ricoh, Verbatim, Optodisc, Prodisc, and Taiyo Yuden are some makers of certified 8x DVD+R discs.
BTW, I have 4 PS2s, 2 play DVD+R, 2 do not, but they all play DVD-R and DVD+R with a ROM book type. -
Full disk burns
15 min @ 4X (mine have really been 12mins)
8 min @ 8X (8 mins and a few seconds)
6 min @ 12x (6min and a few seconds)
So does time really matter, if you need a 8X burner or not -
Where I live, 8x blanks are scarce. I would stick with your 4x burner.
Get a 12x, with DL. (LG makes one, not sure on the US release date) It sounds like one helluva burner.
LG GSA-4120B
40xCDR
24xCDRW 8xDVD-R
4xDVD-RW
12xDVD+R
4xDVD+RW
2.4xDVD+R DL
5xDVD-RAM
40xCD-ROM
16xDVD-ROM EIDE, 2MB
$150Nothing can stop me now, 'cause I don't care anymore. -
xbox:Originally Posted by HAMP
samsung xb drives, yes
thomson xb drives, no
standalones...i guess i can credit you for that
to be honest, i am biased. i feel that the DVD-R coalition is better than the +R. it seems as if the DVD+R coalition is backed by the evil monopolies of electronics that just add a little peperika into their current products and remarket them. Take sony for example...how many versions of the walkman are there?
dvd-r on the other hand, are electronic companies which seem to be inventing instead of innovating. pioneer, 1st to arrive with LaserDisc, and now DVD-R.
thats just my bias thought...i am now done blabbing, please...the last thing we need is a flame war -
These statistics may, or may not, hold true for SL dvd media. I'm leaning more to may not, because with bitsetting DVD+r is quite compatible, it might have just under the compatibility as DVd-r, if not the same.Originally Posted by choirislife923
But this is all a moot point if we are talking about DVDr DL. We have no evidence to suggest either way, at least no empirical evidence. DVD+r DL is scarcely available, and DVD-r DL hasn't even been released yet. So as far as we know, the compatibility rate is probably below that of SL media.Blah, blah, blah
New DVD Burner
By pepegot1 in forum DVD & Blu-ray WritersReplies: 11Last Post: 23rd Feb 2010, 00:57 -
What DVD Burner Do You Use?
By Ray&Paula in forum DVD & Blu-ray WritersReplies: 6Last Post: 20th Mar 2008, 02:01 -
DVD Burner
By jason in forum Newbie / General discussionsReplies: 8Last Post: 15th Feb 2008, 16:02 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15 -
burner not seeing dvd
By SiberSan in forum ComputerReplies: 1Last Post: 1st Oct 2007, 13:46
