im a little confused.
i use to rip dvds to div x and with great results on a 700mb cd. now with a full blown dvd that is 8 gigs i use dvd2one.
without compression the results are poor. if divx was fairly ok but on only 700mb, why are these copies so poor in quality when u shrink the size?
it almost seems like you better off making full blown divx backups onto the dvd using all 4.7 gigs.
any help?
I don't understand. What are you requesting help with?
I've never seen a divx movie that looked as good as a properly done DVD backup. -
That's because with divx, you're re-encoding in a different format, that performs better at lower bitrates. DVD2OneX simply compresses the MPEG2 video stream, but keeps it in the MPEG2 format (without re-encoding), so it will still be compatible with DVD players, but won't take much time doing it. Depending on the disc, the quality will be higher or lower. If the quality is too low when using DVD2OneX's method of shrinking, you can try using DVDRemaster, which has a 'Downsizer' mode, which actually re-encodes the MPEG2 at a lower bitrate, yielding better quality, but taking significantly longer.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 02:35 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 12:20 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 18:59 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25
