Ok, I am having a wierd problem here, the reason it's wiers is cause until 2 days ago I have not had this problem. I have home movies and ones longer than 1 hour are on two vhs tapes, I have been slowly transfering them to DVD, these are the steps I use:
1. I record using a pioneer DVd-recorderI put in tape 1 record, press stop on the recorder than pop in the second vhs tape and record that.
2. I put the Vob files on to my hard drive.
3. I want to join the two VOB clips into 1 vob clip, but first I have to clean up the beging and ends of the clips, for this i use chopper XP.
4. After I have thge clips edited the way i want i use VOBedit to join the clips together.
5. I use ifoedit in order create the ifo's
6. I use TMPGenc to create menues.
Now normally this works 100% of the time, but recently when I pop in the DVD sound in the second half of the movie is out of sync for about 1 second. This makes me think it has somthing to do with the vobedit, any help would be awsome. I will check this thread all the time!
Results 1 to 1 of 1
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
AVSTODVD avi to dvd audio sync problem
By stem300 in forum Authoring (DVD)Replies: 6Last Post: 26th Dec 2011, 13:52 -
Standalone DVD recorder - is there and easier way to ensure audio sync?
By dphirschler in forum Video ConversionReplies: 20Last Post: 30th Dec 2009, 02:57 -
DVD Flick audio sync problem?
By neo*2 in forum Video ConversionReplies: 4Last Post: 6th Sep 2009, 13:51 -
HD dvd conversion, audio sync problem...
By BigJeebz in forum Video ConversionReplies: 6Last Post: 5th Aug 2008, 21:52
