hi.
I'm having problems with some dvd backups, for example I ripped the Shakira Live dvd with dvd decrypter and reencoded it with Instant Copy, using the settings option I've selected the "remove layer break", then I burt the dvd, but when I played it on my dvd player it stops at a point where I think is the layer change on the original dvd, and the same thing happened with other 3 dvds, out of like 30 i have backed up, what I wanna know is if there's a program that can tell me exactly where the layer change is, so i can burn the dvd on a rw and see the video where the layer was to see if it has any problem before burning for real.
Thanks in advance, and I hope I made myself clear, cause I don't speak (or write) english very well.
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 22:52 -
Burning problem with layer break?
By darrenp76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 24th Sep 2009, 12:08 -
HELP!! Dual Layer Problem with Titanium 10
By mnelson220 in forum MacReplies: 20Last Post: 20th Jan 2009, 23:50 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 09:00
