I just got a .bin file that's 740 mb along with its cue. Am I incorrect for thinking this won't fit on a CD-R?
What am I supposed to do next? Do I have to convert them to some other format to get a smaller file?
Which program is best for burning an SVCD on a Mac?
no it will.....
try reading the forum a little more, its been covered lots!
if you have toast 6 use the COPY feature and selecte bin/cue in the left hand column and then browse or drag/drop the .cue in the window
if you dont have toast 6 you can use the multitude of SVCD burners such as Missing Media Burner or FirestarterFX [all avaliable on versiontracker.com]
happy burning
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29
