    Jun 2004
    Hi all, new here in this wonderful forum.
    I have a problem that showed up for the first time today. I tried to author a DVD with Nerovision Express. Everything turned out OK, so even when viewing the preview. But when watching the authored and finalized DVD in the DVD player and in the computer I got coloured pixels distortion in the upper and lower edges of the screen. Very frustrating. NB: They only show up some few seconds in the beginning of some of the chapters.
    What could possibly have gone wrong here and what should I do to avoid similar problems in the future?
    Thanks a million in advance
    /robin
  2. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    what was the source for your dvd? another DVD? home movies you captured? an avi you downloaded? sounds like it's a downloaded avi and nero can't encode it correctly.
    Jun 2004
    AVI captured from broadcast > encoded to MPEG-2 (8000 KBPS) > then taken into Nerovision Express.....
    /robin
  4. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    ok, what mpeg encoder did you use, and is it possible to author with something other than nero? try tmpgenc dvdauthor.
  5. Nerovision Express is your encoder.
    Welcome to the wonderful world of Nero's encoder problems
    I suggest you take your avi, encode it in tmpgenc or Mainconcept mpeg encoder and THEN author it in Ulead DVD or DVDLab, and leave Nero for burning, nothing else.
    Cheers, Jim
    My DVDLab Guides
    Jun 2004
    Well... I have encoded it in TMPGenc and then just "imported" the MPEG-2 file into Nerovision Express...
    I don't know really if I can afford another DVD authoring programme - is there one that is almost equal to Nerovision Express but working perfectly?
    /robin
  7. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    try tmpgenc dvdauthor, there's a free trial. if it works for you it's well worth the money.
  8. Rob. With a properly encoded mpeg, hopefully Nerovision won't mess with it too much...or are you saying that AFTER encoding in tmpgenc, Nerovision has botched it up?
    Cheers, Jim
    My DVDLab Guides
