Just purchased this printer and would like to know from those owning one also if it is better to refill your own cartridges or better just to buy a fresh set of aftermarket brand cartridges? Is it difficult to refill these cartridges as I know you must use a chip resetter and you must drill holes in your original cartridges which came with the printer. I, like most people, am just looking for the most economical way to replace ink as we all know this is a very expensive item if you print a lot of pictures like I do. Any advice would be greatly appreciate. Thank you very much.
Thank You,
GolfNut -
Anyone home? I really would like your input PLEASE. Thank you.
Thank You,
GolfNut -
buy refurbished/refilled cartridges... they are about half the cost of new
You changed your post since 2 hours ago. tsk, tsk... The last time I read it you wanted to know if it was any good or something.
Epson R200, new cheaper disk printer?
By The village idiot in forum MediaReplies: 309Last Post: 26th Mar 2012, 10:56 -
Epson Generic Printer Ink - Here I Go Again!
By leebo in forum MediaReplies: 12Last Post: 29th Apr 2011, 16:28 -
Adding BLUETOOTH to Epson R300 using Dongle ... Which one works?
By Toaster in forum MediaReplies: 4Last Post: 13th Sep 2008, 09:19 -
Sharing Epson Printer
By stiltman in forum ComputerReplies: 0Last Post: 2nd May 2008, 00:12 -
Epson R 300 Printer - Print CD Software
By karlosfandango in forum ComputerReplies: 5Last Post: 29th Nov 2007, 13:12
