I recently updated OSX to 10.3.4. In the process, I can no longer run an external DVD player. In trying to open DVD player, I get an initialization error - A valid DVD drive could not be found.
How do I get the computer to recoginize the DVD burner?
Mac OS 10.3.4, G4, external DVD La Cie.
Thanks,
Hi dabaron,
Moving this to the Mac forum where I'm sure the
regulars can assist. -
Were you using something like patchburn before? I believe those patches don't survive some system updates. Try using this La Cie software first;
http://www.lacie.com/download/drivers/LaCieProfile.dmg
If that doesn't work we'll try something else. -
with OSX 3.3.3 (and possibly with 3.3.4) this happened to a lot of people. Try resetting the PRAM and if that doesn't work, open firmware and reset NVRAM and reset all.
Frances"The earth is one country..." -
FYI Resetting the pram usually does the trick.
But do ensure you have patch burn updated.
ps. nothing see's it? not even Toast?
DVD Maestro Entry Point Not Found Error
By criver in forum Authoring (DVD)Replies: 7Last Post: 9th Aug 2011, 12:42 -
Different DVD file structure? VobBlanker error: Cell Not Found
By siebenbuerger in forum Authoring (DVD)Replies: 3Last Post: 16th Dec 2010, 12:13 -
Help the specified procedure could not be found error
By mn072065 in forum ComputerReplies: 6Last Post: 7th Oct 2008, 22:14 -
Ripping Error: Pack Header Not Found (0x00000000)
By src2206 in forum DVD RippingReplies: 6Last Post: 26th May 2008, 12:49 -
VDecoder init failed?Newbie needs help!
By belleann in forum ffmpegX general discussionReplies: 2Last Post: 27th Apr 2008, 21:59
