If the original source is only about 200 lines of resolution (i.e. VHS, VHS-C, 8mm) then why would I choose a capture rate higher than 1/2 D1 which is 3,000 Kbps for DVD SP.
Does using Full-D1 of 4,500 or 6,000 Kbps provide any quality when your source is so low?
for VHS-C i'd go with 352x240 at 4-5mbits. if you capture at a higher video resolution, your video will not get any better because the source video is at 352x240, so your just wasting file size on useless pixels.
No. 720x480. No. Bloated file.
No. 352x240. No. No, too low (and forced deinterlace, hurts video, yuck
Perfect? 352x480 interlaced MPEG2
http://www.digitalfaq.com/understandsource.htm
http://www.digitalfaq.com/capture/software-resolution.htm
http://www.digitalfaq.com/capture/avivsmpeg.htm
Read those.
Pay attention to resolutions, interlacing rules, bitrate graphs.
and for future reference....
These are found in the GUIDES area of this site (CAPTURE ARTICLES)
<------------------ OVER THERE (and up) ... good thing to use for newbies and oldies alikeWant my help? Ask here! (not via PM!)
Capturing VHS to PC with a high definition resolution...?
By dark_myuutwo in forum Capturing and VCRReplies: 108Last Post: 10th Jun 2016, 12:18 -
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 07:36 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 02:57
