Hi ev'body!
I have a problem with the demux function and FFMPEGX 0.0.9j, MacOSX 10.3. In the manual it says that this function can also be used to demux *.VOB files, but I can't get it working...
I choose "Tools", then "Browse" and select my VOB file, and then I hit "demux".
All I get then is...
...an Error window in which simply is written:
"File Error"
...and then another Error window with the headline
"AppleScript Error:
ac3fix V0.3
Removes bad frames from .AC3 files
Usage: ac3fix <infile> <outfile>
Error level returned:
0: No bad frames found
1: One or more bad frames found and removed
2: Error in execution (2)"
What's the problem, what is my mistake? Am I maybe missing a AppleScript thing? The VOB is working and I can write a AVI from it with no problem...
Thanks for any help!
ISSI
Nope, that doesn't change anything! Neither "50GB1 nor "50GB" (which is what I typed in as the name for my volume) solves this.Originally Posted by Toche
I really wonder why there is a " 1" in the name of my volume, as it is named "50GB".
The strange thing is, that in the "open" area (in the very top part of FFMPEGX) my drive is named "50GB 1" as well! But converting from VOB to AVI works without any probs!
Not even demuxing from my start volume works...
I am puzzled...
Thanks for any further hints, tipps, solutions...
ISSI
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 19:07 -
Video doesn't play back after demuxing by tsMuxerGUI
By mahogany in forum Newbie / General discussionsReplies: 2Last Post: 18th Aug 2010, 22:21 -
Vob file doesn't work, but it used too
By Remyisme in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2008, 07:47 -
Any other options for mkv to vob? Mkv2vob doesn't work 100% of the time
By AndyD in forum Video ConversionReplies: 6Last Post: 12th Mar 2008, 19:13 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 06:58
