I originally posted in the players section, but after some more testing I believe the issue to be with authoring.
It's as if the PS2 is thinking the video is 23.97 fps or something. The reason I suspect this is when I play the video in slow motion, I can see it play 12 frames and then skip 3, and repeat. What this does is cause a slight jump in the video twice a second. And rather than ~30fps, it's showing ~24 and skipping the other 6.
I made a test disc with the following video sources, and every single one exhibited the same problems:
- TMPGEnc - No Audio
TMPGEnc - Bottom Field First - No Audio
Vegas 4
Vegas 4 - No Audio
Direct MPEG2 capture from Hauppauge PVR-250
Hauppauge Capture, edited by Womble MPEG VCR
Vegas 4 - No VirtualDub (Opened recording from PVR-250 directly)
Anybody here using DVD-Lab, do your discs play back smoothly on a PS2?
DVD Lab Pro Play all
By milway in forum Authoring (DVD)Replies: 5Last Post: 10th May 2008, 05:10 -
DVDs on hard drive for back up and play back on TV
By yadoc in forum Video ConversionReplies: 2Last Post: 2nd May 2008, 21:03 -
Playstation 3 Blu-ray playback of scratched discs, 1:1 aspect ratio?
By creakndale in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Apr 2008, 13:22 -
Will a Phillips DVDR3475/37 play DVD +R DL discs?
By c5vetman in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Nov 2007, 12:47 -
Can a playstation 2 play mkv files??
By goodvash in forum Newbie / General discussionsReplies: 6Last Post: 9th Aug 2007, 08:00
