I have a new Apex 660 which seems to play SVCD's fine, and most screeners fine, but over 90% of my TS's have serious lip sync issues. I've tried firmware updates with no luck. I've been burning at 24x and wonder if that's the problem (should I kick down to 4x?) I am also considering a differnet player such as the Pioneer 444 or maybe the new Yamaha 520, but only if they have noticeably better video quality and would allow me to burn at full speed. S9ince they are 2 - 3x more expensive) Anyone with these players and a high speed burner, I would appreciate your feedback. Thank you!
i have the same problem, only with my svcd's, ... i have b&o player, they have confirmed that the dvd should play svcd's ... but after a few minutes the sounds get's out of sync and the image starts hanging and then after some time it's like tottaly fuckt ... should it help that i burn my movie against 4x ? i use 12 speed
Oddly enough, I can't seem to find ANY local store that carries a Pioneer 444, but I did try the same vcd's that desynch in a variety of players and found the following:
The Yamaha 510/520's desync as bad as the Apex
The Yamaha progressive scan flagship player ($1000!!?) worked great
A sony progressive scan worked great and was cheaper, but won't recognize SVCD's...
Not sure why a progressive scan unit would keep synch and the others not, but that appears to be the difference. Too bad I don't have HDTV to use proscan....
Any help out there... anyone? anyone?
VHS tape speed issues
By mjjohnston in forum MediaReplies: 11Last Post: 10th Feb 2010, 09:14 -
Interalce and speed issues using VirtualDubMod
By tgolsby in forum DVD RippingReplies: 5Last Post: 10th Feb 2009, 22:10 -
Mpeg Streamclip synch issues
By filter5 in forum Video ConversionReplies: 1Last Post: 11th Aug 2008, 22:41 -
Audio synch issues when converting to XviD or DivX
By baduncan in forum Video ConversionReplies: 3Last Post: 15th Dec 2007, 14:25 -
Audio synch issues with Youtube uploads
By fusiblelinks in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2007, 22:34
