    Oct 2002
    southern US
    i'm trying to author about 3 large video clips that have already been encoded to low resolution dvd ntsc mpegs using tmpgenc plus with tmpgenc dvd author. i added one file to the be authored with no problem. i tried to add another and got this error message:
    i don't know why it's doing this. i promise u that i encoded each video clip in the same manner. can some suggest a solution to this problem? or can someone plz recommend another good dvd authoring program for me to look into? thanx
  2. Click the Add Track to the left in TDA. Files with different specs must be added in different tracks. If some of your files are PAL and some NTSC you will not be able to do it with TDA, dvdauthorgui is the only authoring app i mangaed to do that in.
    Oct 2002
    southern US
    worked perfectly. thanx!
