"Generating DVD high compatibility borders" seems the last part of burning activity in Nero, since I use the Pioneer DVD-writer DVR-107D. Before I used the NEC ND-1300 DVD-writer. I can't remember such activity then.
My question: while burning on rewritable dvd-media this "Generating DVD high compatibility borders" takes at least two minutes. Is this normal? I did'nt try DVD+R yet, because the burner is just 2 days in use.
I'm still testing.
Tnx already,
Frank
Are you burning less than 1GB ?
You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Posted: Jun 06, 2004 07:06
Yes, I certainly did with testing! Just dragged an arbitrary directory to the burning spot. Is that the reason?
Frank -
The latest build of Nero supports the "high compatibility" mode. This was included by the software companies to allow users creating DVDs that they can create them according to the DVD ROM standard. As you may know the minimum data on a pressed DVD is about 1Gb or 30 mm of data. In some DVD drives and players having less data may cause incompatibility issues. The feature allows the users to write the minimum amount of data and the actual user data should not be less than 1Gb or 30mm.You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
Tompika, I didn't know that, about minimum amount of data, etc. Before the Pioneer I was using NEC ND-1300 writer without any problems or questions (but never recorded such a minimum of data with testing). I presume that explains the time that Nero takes to write those "high compatibility borders"?
Because you seem quit well informed I've one other question about hacked firmware and the Pioneer dvr-107D dvd writer. Of course if you know about this writer. Many are going wild for hacked firmware. But is using hacked firmware making the machine work better?
Tnx for your help,
Frank -
http://pioneerdvd.rpc1.org/#PIONEER_DVR_IDEOriginally Posted by >NIL:
Tons of infos here
http://forum.rpc1.org/index.php
http://forum.rpc1.org/portal.phpYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
TMPGEnc "clip total bitrate too high for a DVD-Video" issue
By dread in forum Authoring (DVD)Replies: 7Last Post: 26th Oct 2010, 16:34 -
TMPGEnc says "clip total bitrate is too high for a DVD-Video" but it's not?
By sasuweh in forum Authoring (DVD)Replies: 24Last Post: 30th Sep 2010, 04:17 -
DVD on Sony Walkman X, "SP" template but high bit rate
By dch888 in forum DVD RippingReplies: 1Last Post: 6th Dec 2009, 16:19 -
"resume play" feature for dvds burned by dvd recorders (pioneer d
By barninga in forum DVD & Blu-ray RecordersReplies: 9Last Post: 19th Nov 2007, 03:11 -
Pioneer DVR-107D mistakes certain DVD+R/DVD-R discs as "blank CD"
By litmus in forum DVD & Blu-ray WritersReplies: 3Last Post: 5th Sep 2007, 14:38
