  1. Hi,
    Hope someone can help, I'm having a lot of problems ripping a DVD. It has multiple angles on the disk but I just want it normal.
    I have tried so many applications but none do what I want, nearly all have the other angles in small boxes on the screen which I don't want. Moviejack 3 worked best and did not put the angles into boxes but this used the wrong angle, and I could not see how to change the angle.
    At the moment I'm using MPG4 Direct Maker which look like a good one, but two problems, again the boxes, but this time it switches view between the boxes (views) every few seconds. Also and a bigger problem, when I play back the AVI its upside down and back to front?? when I make an MPG its the correct way around.
    This is driving me mad, any advice would be welcome.
    All I really want to do is simply rip the CD as one AVI file and in the same angle you would see it if you put the dvd in the player and pressed play, that should be simple.
    Thanks Tony
    Autogk. And uninstall any codec pack you have installed and install each codec manually.
