Hello everyone. I wanted to encode my new dvd Epoch: Evolution but in the final product the audio cuts in and out for seconds at a time for the entire movie. I used DVDx2.2, DVD Decrypter version 3.2.2.0, and divx 4.12. When I first loaded the dvd into dvdx to begin encoding it said this: "Sample not found or audio decoding error. It happens sometimes at begining or end of movie. Select continue will fill audio buffer with blank. Continue?"
So I hit yes and encoded the entire movie. But the audio cut in and out in the final product. So I decided to rip the dvd and try encoding it off my hard drive but that got the same result. I tried changing the output frame rate between 29.97(ntsc) and 23.976(ntsc) but it didn't help. Has anyone had this problem with some other movie? Does anyone know how to encode it right? Is there something I didn't do right? Any help would be appreciated. Thanks for looking.
Results 1 to 1 of 1
MPEG Streamclip: "Audio Decoding Error"
By addresstom in forum AudioReplies: 3Last Post: 30th Aug 2011, 10:12 -
[urgent help needed] audio decoding error
By dc0yy in forum Video ConversionReplies: 2Last Post: 26th Aug 2011, 12:47 -
Error while decoding stream #0.0
By brassplyer in forum Video ConversionReplies: 0Last Post: 26th Aug 2009, 05:04 -
decoding audio for mkv using m2ts file PIDS error dg index used
By davidc78au in forum DVD RippingReplies: 1Last Post: 9th Feb 2008, 22:28 -
MPEG-2 Decoding Error
By shorto in forum Newbie / General discussionsReplies: 7Last Post: 21st Aug 2007, 15:41
