  1. This is an article extract from the cdfreaks site (http://images.bonzi.com/midas/?typ=1&vcid=139&cid=FAST4&aid=138&sid=0&cat=0&sub=0&frq=...5&ccb=77251086)
    A new german transcoding software named "Maximum Copy" has hit the market. With this piece of software you can create 1:1 copies of your favorite DVDs with all menus, subtitles and languages. Movies, which do not fit on a blank dvd (4,36GB), can be recoded without any visible quality loss. Maximum Copy is also capable of creating high quality Audio-CDs from your favorite concert DVDs.
    Main features:
    DVD 1:1 MAX - Copy movie and music DVDs including menu structure and all features.
    DVD Mini-MAX - Compress movie DVDs without big quality loss, so they fit on a recordable DVD.
    DVD Select-MAX - Allows you to freely select the chapters, languages and subtitles for copying.
    DVD Burn-MAX - Burns DVDs without compromises at maximum speed.
    DVD VideoCD-MAX - Convert DVDs into (S)VCDs with automatic splitting. (*)
    DVD 2 Audio CD-MAX - Convert your music DVDs to brilliant sounding Audio-CDs.
    DVD Sampler-Max - Lets you compile individual samplers of your favourite TV-Series, chapters and concerts from different DVDs. (*)
    DVD Converter-MAX - Convert DVDs to AVI-files and AVIs into MPEGs. (*)
    DVD Transburn-MAX - Starts burning while transcoding data
    DVD Syncro-MAX - Adapt the compression ratio for the available space on the recordable
    Note: Due to the new copyright laws, Maximum Copy can not copy any copy protected DVDs.
  2. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    Which includes 99% of all retail DVD releases....
    You are in breach of the forum rules and are being banned. Do not post false information.
    /Moderator John Q. Publik
    Jan 2002
    Not the end of the world!
    Sounds simple to me
    DVD 1:1 MAX - Copy movie and music DVDs including menu structure and all features. Splits to 2 DVDs like DVD XCopy
    DVD Mini-MAX - Compress movie DVDs without big quality loss, so they fit on a recordable DVD. Just Like DVD2One or Shrink in Full Disk mode.
    DVD Select-MAX - Allows you to freely select the chapters, languages and subtitles for copying. Like Clone DVD or Shrink in Re-Author mode
  4. dvd decrpyter.
    DVD2ONE.
    CopytoDVD.
    only progs youll need.
    this thing sounds like a ripoff.
    ^^so whats the point then...sounds like shit to me.
    Nov 2003
    I DON'T KNOW
    DO NOT DOWNLOAD TRIAL. I just downloaded the trial, its all in
    german. So I tried to uninstall the program it gave me warning
    that said
    "Warning uninstall this program may Break Maximum Copy.
    Do you still want to uninstall?" So I click yes.
    Then it said " You must restart to complete the uninstall, so i did
    After I restarted Windows the program was still there.
    I tried to uninstall it like 3 time still no luck.
  6. Banned
    Jan 2004
    Going in Circles
    The worlds fastest dvd copier will never be on the market because there will always be something faster. :P
