I've done a few captures with ATI AIW from some very bad sources and the interlace sequence is inconsistent.
If i used BOB deinterlace (saw this at 100fps.com) with AviSynth to serve to TMPGEnc would it use every other frame for the second field. Maybe it would just throw away every second frame.
If i disabled the AVI readers in the VFAPI tab would it play through TMPGEnc as Broadcast?
Should i just forget it and make everything progressive from such a crappy source?
FPS during encoding process
By godwentpunk in forum Newbie / General discussionsReplies: 0Last Post: 8th Sep 2009, 13:43 -
Anime FPS/Interlaced question...
By alcOre in forum Newbie / General discussionsReplies: 6Last Post: 4th Apr 2009, 10:05 -
Progressive AVI encoding to DVD in TMPEnc - interlaced?
By Xoanon in forum Authoring (DVD)Replies: 16Last Post: 9th Jan 2009, 12:01 -
Re-encoding interlaced order?
By drewzor in forum Newbie / General discussionsReplies: 8Last Post: 27th Sep 2008, 08:06 -
Problem with Interlaced video & Encoding
By miluv2u7 in forum MacReplies: 0Last Post: 19th Jun 2007, 11:55
