What is the proper way?
If i change the vertical height of interlaced material the interlace lines will be the wrong size for the new scale. Come to think of it, the number of interlace lines would be different depending on the scale.
Shoud i separate the fields, resize, and then re-weave?
That exactly what you do. Lately I've been playing around with the following avisynth snippet:
# for 16:9
crop(0,60,544,360)
SeparateFields().LanczosResize(720,240).Weave()
That is for stretching letterboxed material to make it anamorphic. It works good for live action, but small text like subtitles doesn't come out very good. Haven't tried animated meterial yet. -
Thanks, i'll try that.
Since my post i found a couple of interesting filters:
In the package SimpleResize there's a filter included called "InterlacedResize".
http://mywebpages.comcast.net/trbarry/SimpleResize.zip
And another designed specifically for interlaced material.
http://mywebpages.comcast.net/trbarry/YV12InterlacedReduceBy2.zip
There's also a few other interesting filters at http://mywebpages.comcast.net/trbarry/home.htm, but i havn't had a chance to try them yet.
Are you familiar with these, or are you aware of anymore? -
I use a different method that I discovered on the doom9 forums that works really well.
Here is a link to a thread HERE on VIDEOHELP.COM where I talk about that method and where to get the AviSynth "plug-in" you need.
https://www.videohelp.com/forum/viewtopic.php?t=221132
Works for me
This is not only great for resizing but also for applying "noise" filters such as Convolution3D
So this is basically the same idea but only automated?
Wait.......it does a whole lot more than that.
Looks like i've got some reading to do.
Thanks. -
Well YES and NOOriginally Posted by gastorgrab
It does automate the process but I guess the "big deal" is that it does it better than what you can do by simply using SeparateFields() and Weave()
Take a look at this here thread on the doom9 forums:
http://forum.doom9.org/showthread.php?s=&threadid=75734
Look for the posts by user "stickboy" in this thread.
Cropping and resizing interlaced video
By loekverhees in forum Newbie / General discussionsReplies: 9Last Post: 1st Sep 2009, 04:34 -
encode interlaced material witth ffmepg to MPEG2 but get progressive output
By Massa in forum ffmpegX general discussionReplies: 9Last Post: 13th Jan 2009, 12:42 -
Resizing interlaced video - slightly confused at the process
By PTRACER in forum EditingReplies: 2Last Post: 7th May 2008, 07:14 -
Convert interlaced HD to interlaced SD with AVISynth
By jorbje in forum Video ConversionReplies: 19Last Post: 22nd Mar 2008, 18:48 -
Question - Resizing an interlaced video.
By 1gnition in forum Newbie / General discussionsReplies: 26Last Post: 6th Jun 2007, 10:12
