I've created my own DVDs out of 29.97 fps material, and they play perfectly on all DVD players *except* the Playstation 2. Rather than playing back smoothly, it is jerky.
It's as if the PS2 is thinking the video is 23.97 fps or something. The reason I suspect this is when I play the video in slow motion, I can see it play 12 frames and then skip 3, and repeat. What this does is cause a slight jump in the video twice a second. And rather than ~30fps, it's showing ~24 and skipping the other 6.
Has anybody else seen such a thing? My MPEG2 encoder is Vegas 4 (Mainconcept)
I've started a thread in the authoring section.
I made a test disc with the following video sources, and every single one exhibited the same problems:
TMPGEnc - No Audio
TMPGEnc - Bottom Field First - No Audio
Vegas 4
Vegas 4 - No Audio
Direct MPEG2 capture from Hauppauge PVR-250
Hauppauge Capture, edited by Womble MPEG VCR
Vegas 4 - No VirtualDub (Opened recording from PVR-250 directly)
I'm using DVD-Lab, so I'm thinking it may be at fault somehow. -
ps2s are media picky what are you using?
also ps2 has a dvd diag menu you can use to play dvds better, I forgot how to get it but should be in the manual.
Jerky Playback
By electrowiz in forum Video ConversionReplies: 1Last Post: 25th Aug 2010, 17:16 -
jerky playback
By VOYAGER2009 in forum Video ConversionReplies: 19Last Post: 22nd Feb 2010, 06:27 -
Jerky playback on TV from PC using TV Out
By digidude in forum Software PlayingReplies: 0Last Post: 30th Dec 2008, 18:26 -
Playstation 2 plays games & DVD-Rs, but craps out on bought DVDs
By JustPlainDon in forum DVD & Blu-ray PlayersReplies: 3Last Post: 29th May 2008, 18:58 -
Playstation 3 - do they upscale non-BD DVDs?
By snadge in forum DVD & Blu-ray PlayersReplies: 6Last Post: 29th Feb 2008, 20:35
