I've just recently started using a Dazzle 150 and the Moviestar 5.3 software that came with it and I am capturing in Mpeg 2. Problem is that each time I try to capture a video that is longer than 1hour and 7 min, Moviestar splits it. I know why it does this but the fact that I am using Windows XP means that the 4G limit does not apply. I have used DVD2One to rejoin these files after using TMPEGEnc DVD Author to make the Video_ts file but no matter how many times I try the join is always apparent unlike other DVD rips that I have joined. Therefore, I would like to be able to capture a video as 1 file. Does anyone know what program is best to capture video as 1 file (regardless of the size) using the Dazzle 150. I tried Pinnacle Studio 8 but I keep getting an error message when I select the Dazzle as the capture device. Roxio Media Center 7 gives me an error as well. Any help will be appreciated.
Hi
I found the best way to capture with the DVC 150 is to use 'Dvxcel'.(This is the test utility that is with moivestar) .
You will need a patch to capture more than 1 hr 7mins which I can send you. This will enable you to capture 8.5 Gig approx 2hrs 45mins.
You will have to capture without preview with Dvxcel but I have had great results. Then I also use TMPEGEnc DVD Author to burn but each dvd only holds 1hr 15mins. You will also need the latest drivers, link below........
http://www.pinnaclesys.com/SupportFiles/Downloads/Driversanddownloadspages/SoftwareDri...DVC150v340.exe
Hauppauge 150: Odd Problem With Capturing
By Tom Saurus in forum Capturing and VCRReplies: 13Last Post: 13th Apr 2011, 19:42 -
[Sloved] Hauppauge WinTV PVR-150 capturing using off air cable plug
By Wizard23 in forum Capturing and VCRReplies: 4Last Post: 11th Feb 2011, 21:07 -
Dazzle DVC 90 Capturing
By LangleyM in forum Capturing and VCRReplies: 2Last Post: 19th Apr 2009, 09:42 -
hauppauge pvr 150: Need REAL software to record
By SignedupGuest in forum Capturing and VCRReplies: 16Last Post: 19th Feb 2008, 12:40 -
audio sync prob dazzle dvc-150 and virtualdub
By zephxiii in forum Capturing and VCRReplies: 5Last Post: 30th Jul 2007, 13:34
