I am trying to convert from MPG to AVI (or anything really)...The file was created with the ATI VCR, and is 3.75 GB in size. I can play the file fine in Windows Media Player, or the ATI File Player, however I cannot open it in anything else. I want to trim off unneeded pieces (most of it is unneeded) and compress it, but I am unable to get any other program to recognize it. And neither WMP or ATI FP will convert it or export it so that other programs can read it. I think it has to do with the codec it was encoded with. Any ideas on how to convert it to a usable standard would be appreciated. Thanks!
(Below is what Windows Media Player says the codecs are)
Audio codec: CyberLink Audio Decoder (ATI)
Video codec: CyberLink Video/SP Decoder (ATI)
The CyberLink Codecs you list are PowerDVD MPEG-2 filter set. TMPGEnc can make use of them to decode to AVI (File / Output to file / AVI file).
Have you tried TMPGEnc?
Have you tried VirtualDub MPEG-2? -
Yes...I've tried a various array of different programs.
TMPGEnc (version 2.521.58.16, core version 1.98.152) gives this error when trying to select it as a source file: File "C:\Documents and Settings\Sesajic\My Documents\video (May 31).mpg" can not open, or unsupported.
VirtualDub (version 1.5.10) gives this error: No video frames found in MPEG file. -
Do you mean VirtualDub or VirtualDub MPEG-2?
There's also a free plugin for TMPGEnc that decodes MPEG-2 in the tools section; https://www.videohelp.com/tools?tool=243#comments
Converting Ripped Blu-Ray VC-1 Codec to MPG or AVI
By MisterZJ in forum Video ConversionReplies: 12Last Post: 24th Aug 2009, 13:12 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41 -
Philips DV624/37 AVI (XviD) Problems (Not QPEL/GMC)-could it be the codec?
By wingalls in forum Newbie / General discussionsReplies: 4Last Post: 2nd Nov 2008, 00:13 -
best format/codec for compressing an mpg???
By cduval04 in forum Newbie / General discussionsReplies: 1Last Post: 28th Dec 2007, 19:31 -
Codec problems with downloaded avi files?
By aelfheah in forum Video ConversionReplies: 3Last Post: 16th Jun 2007, 07:48
