I have a SVCD of a family event and I want to make a copy on VHS tape for my aunt. She does not have a DVD player. Can this be done if I connect my DVD standalone to my VHS tape recorder? My VHS only has a video and mono sound inputs, would I use a Y connector and put DVD stereo out into mono? Thanks Foz
Results 1 to 10 of 10
Foz the newbie
Sounds like you know what you're doing for this project. This would probably be the easiest way to go. And yes, you should use a Y adapter to convert stereo to mono (for the best sound), and so the left and right channels don't get confused. Here's a pic that may help you out (but you probably already know what you're doing). Sorry if my Paint skills are lacking
Also, the Y adapter should be 2 males (stereo and mono) to a female (mono). Then the rest of the cords will be male to male. -
Quite a few VHS recorders convert to mono ifyou hook up only one audio input. You should check your owner's manual before you go to the y adapter. I have added noise this way that I did not want.
Still a few bugs in the system... -
Thanks to both of you, and to you Video Guy, your diagram was excellent. I don't remember ever getting such good advice on any post I have made. Thanks Foz
Foz the newbie -
Don't use a Y-connector to join the stereo outputs!
If you use a Y-connector on a stereo output you will be shorting the left and right channels and you may damage the DVD player. Use only one of the outputs and then use the menu in the DVD player to set the audio to mono.
A Y-connector can be used to connect a mono output to a stereo input."Art is making something out of nothing and selling it." - Frank Zappa -
Zippy P, I have already hooked with a Y connector and recorded the SVCD. All seemed to work OK, but when I move my DVD player back to the stereo I had it previously connected I will find out if I damaged the DVD stereo output. Will reply when I find out. Thanks Foz
Foz the newbie -
News to me!Originally Posted by ZippyP.
ha...i did that once on my computer..merging 2 stereo lines into 1 because i didnt want to swtich sources...luckily, my PC is still aliveOriginally Posted by Foz
Reply to All, Well I reconnected my standalone DVD to my stereo and audio worked fine in stereo, no damage to audio. I also played my SVCD to VHS tape recording and it was great, just as much quality as the SVCD, except for the mono audio. So thanks again to ( Video Guy ) for your drawing and advice. Foz
Foz the newbie -
I think it's safe. I've never heard of problems since the outputs are impedance-protected from shorts. They're not zero ohms, but rather something like 600 or 1K if memory serves.Originally Posted by ZippyP.
Speaker outputs are lower, 4 or 8 ohms and I wouldn't want to short those
vhs tape will NOT move through vhs recorder at all
By tepeco in forum RestorationReplies: 52Last Post: 24th Oct 2022, 13:31 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
How can VHS tape color loss be possible? ("tape fade")
By lordsmurf in forum RestorationReplies: 31Last Post: 18th Oct 2010, 10:32 -
HDTV VCR recording, VHS TAPE?
By jb66 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Oct 2008, 18:45 -
Recording a NTSC VHS Tape with a PAL DVD Recorder??
By Lanno in forum DVD & Blu-ray RecordersReplies: 10Last Post: 5th Sep 2007, 04:42
