Results 1 to 9 of 9
  1. Member Devanshu's Avatar
    May 2003
    What's the best software to remove spyware?
    USA
    I like Spybot Search and Destroy, but make sure to get the latest updates. It's free and easily configurable.http://www.safer-networking.org/
  3. Originally Posted by redwudz
    I use that in conjunction with Ad-Aware, you can use the free edition. Either misses some that the other catches, so I think it's good to use both.
    http://www.lavasoftusa.com/
  4. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    I Use ad-aware along with CWShredder....does the job...CW reoves hijacked fies,web, etc...
    What We Do In Life, Echoes In Eternity....
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Try here:
    http://www.spywareinfo.com/
    Download CWShredder and Spybot Search And Destroy(check for updates as soon as you download it) to check for spyware.
    If that doesn't completely remove it:
    Download Hijackthis and post the log onto the message board on the above web site...within a day or so someone will help you get rid of the problem.
    READ the FAQ first. They will respond ALOT quicker if you follow the rules in the FAQ.
  6. I choose "D - All of the above".
  7. As noted above Spyware S&D is good... but use it along with Ad-aware V6 (free version).
    Also, add to your arsenal ZoneAlarm Personal (again free)
    I feel comfortable doing a cc order from my machine...
  8. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    I have been using Pest Patrol for over a year, but the update feature disabled itself and gives errors now I'm looking for a new one now.
  9. Member Devanshu's Avatar
    May 2003
    Thanks guys. I have to do some chemistry stuff right now but I'll download Spybot Search and Destroy, Ad-Aware, and CWShredder and let you guys know if I have any more problems. Thanks again.
