hey, im a complete n00b to this and i couldnt find a guide regarding this and i dont know if this is the right forum to ask this but ill just give it a go..
i just want to know what i need to have to transfer a hi8 tape to a dvd-r? do anyone have a guide about this?
thanks
What sort of camera fo you own, do you have a fire wire and/or a capture card, and a burner?
Hello. -
i have a nvidia geforce 3 64mb grafic card.. im not sure about if it has capturing.. and i have a dvd burner
but the thing with the camera is that its broken and before i rent one i want to make sure that i can do this -
Does your computer have a fire wire port or a fire wire card? The best captures are direct transfers from a camera to your computer via fire wire. If you can get one installed, do so, as the fire wire cards are relatively inexpensive.
Rent a digital 8 camera if possible, and make sure it does have a fire wire port.
Now, get a 4-pin to 6-pin fire wire cable to hook from your camera to your system. Use a freeware program called DVIO to do the video transfer. Once the transfer is complete, you will need a program to convert the video (DV AVI) to a MPEG DVD. Check the Convert section for one you think you may like.
Now that your is an MPEG file, you must author it to make the files (.BUPs, .IFOs, etc.)your burner will need to make a DVD. Check the Author guides here.
Then burn, baby, burn!
Hello. -
Also, if you know anyone with a dvd recorder and a hi-8 camera, check with them. You will get a very good transfer using the firewire or even the s-vhs input if available. Positive - very easy to do, trandsfers and records all at the same time. Negative - not as customizable ( menus / chapters ) as if you transferred and burned on a pc/mac.
Sony Hi8 has been defective but want to play the Hi8 tape
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 22nd May 2009, 23:06 -
Hi8 to DVD
By 21Wiz in forum Newbie / General discussionsReplies: 3Last Post: 2nd Oct 2008, 02:25 -
hi8 to dvd
By jmoore_cne in forum Newbie / General discussionsReplies: 6Last Post: 3rd Jun 2008, 14:45 -
Hi8 vcr, better playback than a Hi8 camcorder?
By Knightmessenger in forum Capturing and VCRReplies: 8Last Post: 22nd Dec 2007, 02:11 -
Will cheap new Hi8 camcorder output better than old, worn Hi8 camcorder?
By ErikL7 in forum RestorationReplies: 7Last Post: 2nd Sep 2007, 07:26
