Hi to everyone !!!
I have a lot of problems so i did not know to witch section should i post my questions...
I have more avi files of the same movie and i want to have them on the same dvd (as much as possible not to lose from quality)
My avi's are in PAL format and i'm in a dvd NTSC region....
I'tryed with the guide "AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD" (using DVD2SVCD)--for conversion avi-->dvd, and then "User guides - PAL / NTSC DVD Conversion (patch method)" (using IFOEdit) -- for dvd pal --->dvd ntsc. Really good method because it is verry easy to use !!!...And it worked good for singles avi's, BUT i dont know how to use this if i want more avi's to the same dvd...
Could you tell me another method to get this done ???
I remind you that i need something to convert : a FEW (as many as possible) AVI's from PAL ---> ONE dvd in NTSC
Thank you .
Please do not cross post / Baldrick
Closed Thread
Results 1 to 1 of 1
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
Subtitles not added during conversion of Pal to NTSC 2 avis with 2 sup file
By unity860 in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 3rd Apr 2008, 07:54 -
converting PAL AVIs into NTSC DVD
By exekutive in forum ffmpegX general discussionReplies: 0Last Post: 24th Jun 2007, 19:20
