I have Panny E80 and would like to use Ram due to less pixelation when copying 3 hours worth of show and then convert into DVD-R so do you know of any drive that can read RAM and what authoring program do you recommend?
Would like to hear your input before I shop.
Thanks!
Results 1 to 11 of 11
You don't have to spend a lot of money to buy a DVD-Ram writer, many DVD-Rom (readers) are compatible with DVD-Ram media.
Toshiba SD-1612 / 1712 / 1812 reads DVD-Ram. -
I have the LG DVD burner to read and write DVD-RAM and i have the Panasonic E80. The LG work with DVD-RAM works as a removabel hard drive when you install the DVD-RAM driver's you can even download software on DVD-RAM just like you do o a hard drive. www.newegg.com has them.
Shouldn't surprise you but Panasonic makes dvddram drives too.
What kind of computer is it for? -
LG has released (not available in US yet) a new double layer burner with 8x+ / 8x- / 5x RAM. GCC-4120B
http://www.cdfreaks.com/news2.php?ID=9614
https://www.videohelp.com/dvdwriters.php?DVDnameid=414&Search=Search&list=0#commentsNothing can stop me now, 'cause I don't care anymore. -
ioMega (remember, Zip) makes also DVD-RAM writers. They are same as LG. It supports all formats, +,- and RAM.
Except that there is no SD-M1812, only SD-M1802 and it doesn't read DVD-RAM. The SD-M1802 doesn't even show up on Toshiba's US website any more. The LG, Lite-On, and Samsung's current DVD-ROM drives are also able to read DVD-RAM discs.Originally Posted by gastorgrab
Why does anyone need a DVD-RAM writer, if he/she only needs to read DVD-RAM discs and write to DVD-R discs? The Pioneer DVR-107D/A07 can also read DVD-RAM discs, just in case you also need a DVD burner. -
Originally Posted by Synergy
I'm getting conflicting info about that. When i bought my Pioneer DVR-107D, i'm sure the specs at the site listed DVD-Ram as a compatible format but Nero Info Tool doesn't.Originally Posted by Synergy
Do i need to install "InCD" (Nero 6) before it shows up? -
There was report that earlier version of the Pioneer 107D had trouble reading certain formats of files from DVD-RAM discs, but Nero Info Tool should report DVD-RAM compatibility without any problem. See, for example, the middle part of the following page:Originally Posted by gastorgrab
http://www.cdrlabs.com/reviews/index.php?reviewid=225&page=Features
or the ASUS model which is a rebadge of the Pioneer 107D:
http://www.cdrlabs.com/reviews/index.php?reviewid=228&page=Features
Try updating the firmware and Nero Info Tool to the latest version, and see if there's any improvement? -
GCC-4120B is LG's DVD-ROM drive model name. The new burner is GSA-4120B and it's 12x, not 8x for DVD+R. It's a DL drive but no DL media is bundled at least in South Korea.Originally Posted by ViRaL1
I think this is the best DVD-all burner for US$70.
http://www.pc-success.co.jp/hyouka-p.php?prd_cd=P0303062500-010
8x DVD+R 8x DVD-R 4x DVD+RW 4x DVD-R 3x DVD-RAM
GSA-4120B is more like US$100. It adds 12x DVD+R (SL), 2.4x DVD+R DL, and 5x DVD-RAM. But the price will soon come to US$80 and then US$50, especially with the arrival of 16x DVD+R writers. -
The last time i checked it was before "The Big Crash". I rechecked it, two weeks after my Windows reload and it seems fine now.Originally Posted by Synergy
Must have been another cause for the problem.
Can someone recommend a DVD Converter that is compatible with Aegisub?
By Djard in forum SubtitleReplies: 3Last Post: 17th Jun 2011, 03:26 -
Can anyone recommend me a new DVD player
By johnyccc in forum DVD & Blu-ray PlayersReplies: 3Last Post: 22nd Jan 2010, 21:13 -
Recommend a new dvd recorder
By colt4523 in forum DVD & Blu-ray RecordersReplies: 12Last Post: 29th Aug 2009, 00:02 -
Which DVD Recorder would you recommend?
By DJL82 in forum DVD & Blu-ray RecordersReplies: 48Last Post: 30th Dec 2007, 12:44 -
Buying a new dvd player soon, please recommend one
By dimmy32 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 6th Dec 2007, 13:57
