Results 1 to 10 of 10
  1. Please help me! I have a movie on a 683MB I can't burn it to a 700MBs CD.
    When i add the file it becomes to more then 800MBs file. What is the wrong??? Can anyone help me with my problem? Please if yuo know what the wrong is then help me!
    USA
    Need more information. What programs are you using? What type of file; SVCD? You may be able to overburn, depending on your burner and burner program. If you were using an image file, you can get at least 830MB on a 700MB CD.
  3. I think the file is a .avi and the program i use is Nero, Nero SmartStart.
    have you seen the picture?
  4. i am betting you are trying to burn it as a video cd, so you can play it in your dvd player? well the only way you are going to burn that avi file is in data mode and that won't play in your dvd player.
    How Big A Boy Are Ya?
  5. How do I burn so i can watch at my DVD player?
  6. Originally Posted by Imaz
    rofl@that.
    you never said what picture it was..hehe
    anyways,look over to your left and youll see a menu,go there and look for converting avis to dvd
  7. As I read on your post I dont think you are going for DVD, noticed you say you want to put it on 700MB disk. So first thing if you want DVD video you need a DVD writer and 4.7GB disks. If what you have is a CD writer what you are looking for is VCD, so go to the convertion section and look for guides on changing avi to VCD or SVCD is your DVD player can handle them.
    hope this helps
  8. My DVD-player can play VCD i know that. But i want a VCD. Only so i can get the movie at the cd and just watch at my DVD-player....
  9. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    Use a program called dvd2svcd. You will also need tmpgenc or cinema craft encoder. there are guides to use these programs located to the left of your screen.
    Donadagohvi (Cherokee for "Until we meet again")
  10. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    Also it's probably going to take 2 discs.
