What kind of conversion software would I need to convert an MKV file to something I could run on a palm zire 72? Also, what software could I use to remove one of the audio tracks(it's dual audio.), assuming that's what it's called?
Okay, nevermind, I figured it out myself(more or less.). It turns out that what you have to do is save the audio and the subtitles, and then get a copy of just the video without the audio(As far as I can tell, I was able to easily do that with virtualdubMOD just by saving it as an AVI.). Then, you use TMPGenc to merge the audo and video, and when you do this, there's an option in ffdshow that lets you manually put a certain subtitle file on all movies using that codec. So you just set that to the subtitles for the movie you want them for, and VOILA! MKV to AVI in under half an hour(not counting the processing of the stuff itself.).
My TV doesn't run either .DTS and .AC3 file from .MKV movie
By galodoido12 in forum AudioReplies: 2Last Post: 4th Feb 2012, 00:29 -
Simplest way to convert 1080p h264 mkv to 720p mkv?
By aer in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2011, 11:16 -
Best quality option to convert 1080p mkv to 720p mkv
By carlmart in forum Video ConversionReplies: 5Last Post: 14th Mar 2010, 08:17 -
25fps 1080i mkv convert to 24fps 1080p or 720p mkv?
By brent1a in forum Video ConversionReplies: 6Last Post: 9th Feb 2010, 10:57 -
How to convert mkv to ps3 viewable format maintaining mkv subs in new file?
By shuyinliquid in forum Video ConversionReplies: 2Last Post: 14th Dec 2009, 02:17
