OK...this time I know I have done all there is to be done in my search for making this work. What I want to do is take the fonts that I have applied to the canvas, and then bend them in a circular for, or wavy forms...something like the text art in word does. Can anyone tell me how to do it!?
Smile
Smile -
I haven't used PSP in many moons, but from memory.
You have to use vector based or something like that
Look for that option in PSP -
I used the vector based input but it only allows to move it around but not twist it into a circle....any other ideas
thanks though stiltman
Smile
Smile -
PSP = Paintshop Pro or Photo Shop Pro?
I didn't think there was a Photoshop Pro but since I still use version 6 I wasn't sure.
Also how are you wanting them in the circle...so the letters lay flat or so standing up...grrr....like the numbers on a clock or the lable on a beer can...
You know what I mean? -
Paint Shop Pro...
I want them like the numbers on a clock.
Sorry, I couldn't figure a way to better express what I meant, but your clock/beer can expression is perfect
Smile
Smile -
I'm running V5 of PSP ... I don't think it will support this... may a later version..
Now, In the past when I've wanted to do this I've used Corel Draw.. if you've got an old copy fire it up. It supports this and the imagery is vector based.
Hey... have a look see at MS Word... betcha they got something as well. (will more than likely be bitmap based though) -
Corel Draw will do it. You can take any text and twist it in whatever way you want. You can even manipulate each character if you want. I guess Adobe Illustratior is similiar to Corel Draw, vector-based.
It can be done in later versions of PSP
http://moonsdesigns.com/tutorials/psp8/textonpath.html
HTH
RogerThere are many ways to measure success. You just have to find your own yardstick.
PSP Test Clip: Need someone with a PSP to test for me!
By FulciLives in forum Portable VideoReplies: 5Last Post: 17th Feb 2009, 20:42 -
I got a PSP.
By Xylob the Destroyer in forum Off topicReplies: 4Last Post: 10th Feb 2009, 22:10 -
My XviD4PSP PSP video conversions are not supported on PSP
By godfist314 in forum Portable VideoReplies: 3Last Post: 18th Aug 2008, 10:59 -
Downgrade your PSP to version 1.5 using your PSP battery
By chrise in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2007, 08:27 -
Nero 8 Recode to PSP - No Title on PSP?
By sonicm in forum Video ConversionReplies: 1Last Post: 6th Dec 2007, 14:13
