Using DVD Decrypter / Shrink and the only titles out of 60 I can't get to work on Decrypter are Road to Perdition and Drowning Mona.
What's up? They both just stall out on Decrypter - I tried successfully with a bunch of movies, came back to those two and they still don't work. Any ideas?
You may want to try playing them on your pc before ripping. Use a dvd playback software like windvd or ulead dvd player. Then rip in FILE MODE with DECRYPTER, then use DVD SHRINK to compress.
__________________________________________________ ___________
No dice, I played it for about 10 mins on my PC and then tried again - still hangs at 46% on Decrypter in File mode.
Are you using your dvd burner to rip? I see in your computer specs you only list a Sony dvd burner. It could be those 2 discs are scratched or something and the burner can't read it through the end. If you can try it on another dvdburner or dvdrom like a friends pc or something.
on the slow PENT 933 pc again! -
Yeah I am using my burner to read and rip. The thing is, these are both brand new discs.... i ripped a couple that were pretty shady looking and they came out fine.
dunno then what could be the problem. if their brand new perhaps you can take it back and get new ones.
DVD Shrink also works with play while ripping trick. May want to give it a try.
Hello.
Portable Decrypting Software
By Drazick in forum DVD RippingReplies: 4Last Post: 20th Aug 2010, 17:11 -
DVD Decrypting Question?
By daz1976 in forum DVD RippingReplies: 5Last Post: 14th Jan 2010, 15:44 -
decrypting a dvd with MTR 2.6.6
By andyx181x in forum MacReplies: 11Last Post: 2nd Dec 2007, 09:05 -
Errors decrypting dvd
By Beaker14 in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 10:59 -
Decrypting Software
By csaplot in forum Video ConversionReplies: 1Last Post: 22nd Jul 2007, 09:54
