I converted a divx avi to mpg using the tutorial on this website using TMPG and it worked fine, but now i get an error when i try to burn it to VCD using Easy Cd Creator 5 platinum and Nero 5.5.5.6. It says the the mpg will not play in a dvd player because of "System Clock Reference",
now i know that i could re-encode the VCD using the built in nero or ez cd programs but i just spent 8 hrs converting the file in the first place using TMPG. I was wondering if there is a reason why this happened and how i could make it so that i dont have to convert it to mpg and then convert it from mpg to mpg again so it will work.
Please Help
Results 1 to 1 of 1
Best settings voor TMPG Express MTS Files to Divx Avi
By jeremyotten in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 8th Mar 2008, 09:36 -
TMPG DVD Author 3 won't open FVFW avi
By jasoncolz in forum Authoring (DVD)Replies: 0Last Post: 7th Dec 2007, 15:21 -
AVI to VCD
By northy44 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 6th Dec 2007, 06:27 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
