Hi,
I have borrowed from school a Sony DSR-PD150 DVCAM camera and I would like to transfer some test shots I made to my computer, using a firewire (IEEE1394 / I.link) cable. I do NOT have the drivers for the camera, e.g. I do not have the original CD-ROM, but I have done such transfers with other camera models a good number of times. Anyone know where I could get my hands on the correct driver? I installed 2 or 3 of them but to no avail. The Sony web site is a total mess so I could not find the correct driver, if even it is available for download.
Any help is greatly appreciated because if I cannot transfer to my PC I have no idea if what I filmed is good or not and what settings to change.
Raggart
if you're using firewire to transfer video, you shouldnt need a driver for it. the only thing you need a driver for is your firewire card. when you plug it in to your computer, windows should automatically recognize that its a camera and ask you what program you want to use to capture video.
Thanks for the tip. I checked my Firewire connectors, which are integrated with my motherboard; the ones that are on the front of the case are NOT connected to the motherboard, while the USB connectors, just beside, are. I simply switched to another connector and *tada* capture worked perfectly.
Thanks for the help!
Help! Where Do I Get New Drivers?
By RayPaula in forum DVD & Blu-ray WritersReplies: 3Last Post: 13th Jan 2010, 10:13 -
Sony DSR 200 rewind problems
By ssadams in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 29th Feb 2008, 08:37 -
"Sony Digital Imaging Audio" drivers problem...HELP!!!
By nick_gr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 2nd Nov 2007, 16:43 -
Looking for some Vista drivers
By t_jay17 in forum ComputerReplies: 3Last Post: 9th Oct 2007, 03:29 -
drivers
By Mr anderson in forum ComputerReplies: 2Last Post: 29th May 2007, 05:36
