Here is my problem, i'll try to make it short. I have an Aopen 8X8 8800 drive. When i first got it, i had some verbatim digital movie -r & +r discs. The -r discs would burn around 7.5X, the +r around 6X. So i was kinda happy with the drive. I bought some Memorex 4X -r and they burned at 4X, no big deal. I recently bought some Ritek G05 8X (-r) and some Prodisc 8X (+r) discs. DVD Identifier identifies them as 8X discs. The problem is I can only get them to burn a 4X. I am usuing a number of programs to burn with. I am using the lastes version of CopyToDVD (trial version) and ImageToolBurn (nero 5.5.X & 6.X.X) as the burning engines. Is it my drive that won't recognize the 8X or the software. When i got to burn with CopyToDVD, i set it for 8X and it says in the details, Burn Speed 8X, Effective 4X. And it only burns at 4X. Any suggestions or help?? Sorry for the long question, just getting a little frustraded with the whole thing.]
It could still be possible that the drive maker hasn't added those discs to the firmware. You may want to contact the tech people @ AOpen and let them know the DVD-Identifier string so they could help you out and either add them or let you know what's up.
Tom -
You could just order disks that are known to do 8x on your writer. But since you did 7.5x, why did you change media?
I switched media cause verbatims are expensive. I got the G05's and the prodisc 8X for $1 a disc pretty much. Plus i figured i'd try something new.
does this work
By sve in forum TestReplies: 7Last Post: 21st Apr 2012, 23:15 -
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 23:13 -
Does not work.. What can i do?
By schr2004 in forum ffmpegX general discussionReplies: 0Last Post: 24th Jul 2010, 16:21 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
How much do you work? (work = doing something you are getting paid for)
By Baldrick in forum PollsReplies: 20Last Post: 26th Nov 2007, 16:35
