Hello all
Brand new to any type of cd/dvd burning, so maybe this may sound an easy fault?
I have got nero 6, and i am trying to burn some avi. movies to dvd.
It takes about 4 hours to encode and burn, the picture looks great, and the sound is good quality(but what do i know), but it is out of sync.
The audio is out by about 1 second?
Any ideas plz?
Also is this the best way to burn avi movies? or should i do something else?
Please be basic in your answers plz, as i am not the master of english.
You need to read a little, go to CONVERT in the HOW TO menu to the left, and look up some AVI to DVD guides. It doesnt take long to learn, and the quality will be better and audio should be in sync. Good luck, and dont hesitate to post your questions if you encounter more specific problems.
How is the audio out of sync? 1 second ahead or 1 second behind?
Demux the audio from the video (TMPGEnc, guides to the left), then:
ahead - open the sound file in an audio editor, delete 1 second from the beginning, then remux
behind - open the sound file in an audio editor, add 1 second of silence to the beginning, then remux
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 12:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 18:24 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 02:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 02:19
