I've tried installing the Matroska pack and the lite version and I still have no luck, I can see the video in virtualdub so I know there is nothing wrong with it. I've been trying for quite a while, is there something I'm doing wrong? It's also the same with ogg media with subtitles, I installed all the neccesarry filters and codecs and nothing. strange thing is if there are no subs then the file plays fine. btw, I have vobsub and directvobsub and I am using Windows Media Player Classic.
here's some info from Gspot about a .ogm that I have been trying to play:
Name.........: Angelic Layer 01 [a-g] (DivX511) [813C683E].ogm
Filesize.....: 175 MB (or 180,210 KB or 184,535,800 bytes)
Runtime......: ?
Video Codec..: DivX 5.0
Video Bitrate: ?
Audio Codec..: ogg_vorbis_1 (0x674f) Ogg Vorbis
Audio Bitrate: 104 kb/s (52/ch, stereo) VBR
Frame Size...: 544x400 (1.36:1) [=34:25]
I have the ogg filters and subtitle filter, I also have ogg vorbis, also rendering fails when I try to play this file, also if I take out the subs it plays fine. -
Not sure, but i thought i remembered reading about different types of SUB files. I'll just have a look in the Tools section......yes, here's something.
In the tools section, the Subtitle Tool details the subtitle formats it converts between:
"Subtitle Tool is program for editing, time shifting, speed changing, joining, spliting and checking subtitles. Reads about 7 subtitle formats (MicroDVD, SRT-SubRip and their modifications). Convert into MicroDVD, SRT, SSA".
https://www.videohelp.com/tools?tool=606#comments
Does VobSub play all of the different formats?
I would uninstall VobSub if it were me. I think Matroska Pack uses the DirectVobSub (VSFilter.ax) which is newer. I don't know if installing VobSub (older) over Matroska Pack (newer) will disable the newer filter, but it can't hurt to try.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
External subs don't play correctly with Anime .mkv with embedded subs (.ass
By Reveur in forum Software PlayingReplies: 1Last Post: 8th Nov 2011, 03:20 -
MPEG TS recorded from DVB: impossible to extract subs good enough for OCR
By edea in forum SubtitleReplies: 25Last Post: 25th Oct 2011, 13:07 -
Multi mkv files with subs into one disk to play to all bluray players
By fits79 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 27th Dec 2010, 07:27 -
Mux .sup (standard definition) into MKV file too. Impossible?
By sdk83 in forum DVB / IPTVReplies: 1Last Post: 4th Nov 2008, 08:21
