I did the general mistake and istalled all the codecs and codec-packs I could find.
At one point I had 93 codecs installed....
With Add/Remove I got rid of some of them, and I now have 58 left (Gspot tells me)
And I can't seem to get rid of them.
I've tried with WMP and I've tried with Control Panel. When I remove them from CP and restart my comp they're BACK..!!!
What can I do - any suggestions?
...000....000....
Angelot :-D -
Short of a format/reinstall, all I can think of at the moment (short on time here, need to run in a minute or two) is to give VCSwap a go. It doesn't give you the ability to uninstall codecs but it can let you deactivate them. It's potentially dangerous, though, if you don't know which you should deactivate and which you should leave alone. Expect some trial and error testing...
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 15:29 -
Please explain codecs to me: codecs within codecs?
By idsane in forum AudioReplies: 5Last Post: 2nd Sep 2008, 15:39 -
How can i remove/fix some broken codecs?
By GangstaRap in forum Newbie / General discussionsReplies: 23Last Post: 23rd Feb 2008, 05:04 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 20:52 -
How to remove codecs in Windows Vista?
By dogenzaka in forum Newbie / General discussionsReplies: 4Last Post: 14th Aug 2007, 00:58
