Hi guys,
Does any of you guys know how to use DvdXcopy ?
My issue is this: I ripped the dvd but didn't copy on a blank right away. So I have the folder created by the software and now I want to transfer it on a disk.
Any ideas ?
Thanks.
If what you have on your hard drive is an ISO image of the original DVD, you can simply map to the image with a virtual drive letter and use that virtual drive as the input to DVDXCopy.
If what you have is not an ISO image but a bunch of VOBs and IFOs, you don't have to worry about virtual drives, simply point DVDXcopy to your VIDEO_TS.IFO and it should work. -
Yes, it's a bunch of crazy extension files in a folder created by the software, having the same name (DVDXCOPY). 4 of the files inside, have almost 1Gb and I presume they are the actual movie files. So, can you please tell me in a few steps, for dummies
, how to copy the content of this folder on a disk ?
Thanks a lot !
