Hello!
I want to convert a MPEG2 (8MBit/s) into another MPEG2 SVCD or MPEG1 SVCD, but i can't open my MPEG2 file with TMPGEncoder. What can I do ?!?
Thanks a lot! I need to do it very quickly!
Bye!
You need dvd2avi. Load the mpeg 2 file to dvd2avi and select file>save project. The program will create 2 files, a dummy one for video and one mpa for audio.
Feed to TMPEGenc those files. Load then the template you wish and hit encode. That's it!
See also the guide of this site "mpeg 2 to mpeg 2" for more details -
Thanks, but I have a problem: my MPEG2 file is 544x576 (PAL) recorded with Hauppage via satellite ... when i open it with DVD2AVI I see very large green areas, and so the video is very strange.
But i can see "perfectly" this video with mpeg2 elecard decoder for Windows Media Player (but there are 9 micro-square in the upper right and i see the upper side in the lower part, as if there is a mirror) ....
What can i do ?!? to see correctly this video file ?!?
Thanks again! -
the little 9 squares is elecards logo
A mirror effect is done in tmgpenc, thats what caused it
It is not your fault, but tmpgenc has some trouble with encoding to svcd, such as slight jumpiness in video if you encoded to widescreen
Trouble Editing/Trouble Base Media?
By SlickPen in forum EditingReplies: 0Last Post: 20th Mar 2011, 19:53 -
Advc trouble
By runnernorth in forum Capturing and VCRReplies: 3Last Post: 15th Jan 2010, 16:20 -
Having Trouble Degraining
By Framework in forum RestorationReplies: 7Last Post: 20th Mar 2009, 16:27 -
Trouble with OE
By alegator in forum ComputerReplies: 4Last Post: 6th Feb 2009, 14:52 -
PS/2 Trouble
By gooberguy in forum ComputerReplies: 22Last Post: 19th Jun 2008, 18:08
