I need your help.
I installed the Gordian Knot. One hit start it loads VirtualDub which works for some time and them the window pops out that I have the following error:
"An out-of-bounds memory access (access violation) occurred in module 'ntdll'".
Before I had SimpleDivX which also stopped w/o any errors but also w/o output and I decided to replace it with Gordian Knot.
Here is more detailed info from crashinfo file:
VirtualDub crash report -- build 2178 (release)
Disassembly:
77f83960: 45 inc ebp
77f83961: 0c89 or al, 89
77f83963: 45 inc ebp
77f83964: 08743964 or [ecx+edi+64], dh
77f83968: a118000000 mov eax, [00000018]
77f8396d: 8b4030 mov eax, [eax+30]
77f83970: 8b400c mov eax, [eax+0c]
77f83973: 8b400c mov eax, [eax+0c]
77f83976: 83c02c add eax, 2c
77f83979: 50 push eax
77f8397a: 681a37f877 push 77f8371a
77f8397f: e8a723ffff call 77f75d2b
77f83984: 8b4508 mov eax, [ebp+08]
77f83987: 8d443810 lea eax, [eax+edi+10]
77f8398b: 50 push eax
77f8398c: 57 push edi
77f8398d: 682637f877 push 77f83726
77f83992: e89423ffff call 77f75d2b
77f83997: 83c414 add esp, 14
77f8399a: 57 push edi
77f8399b: e89a910100 call 77f9cb3a
77f839a0: 8a4605 mov al, [esi+05]
77f839a3: 2410 and al, 10
77f839a5: a810 test al, 10
77f839a7: 884705 mov [edi+05], al
77f839aa: 740b jz 77f839b7
77f839ac: 0fb64704 movzx eax, byte ptr [edi+04]
77f839b0: 8b448358 mov eax, [ebx+eax*4+58]
77f839b4: 897838 mov [eax+38], edi
77f839b7: 0fb70f movzx ecx, word ptr [edi]
77f839ba: 8b4510 mov eax, [ebp+10]
77f839bd: 0108 add [eax], ecx
77f839bf: 0fb70f movzx ecx, word ptr [edi]
77f839c2: 294b28 sub [ebx+28], ecx
77f839c5: f6470510 test [edi+05], 10
77f839c9: 668b00 mov ax, [eax]
77f839cc: 8bf7 mov esi, edi
77f839ce: 668907 mov [edi], ax
77f839d1: 750d jnz 77f839e0
77f839d3: 8b4510 mov eax, [ebp+10]
77f839d6: 8b08 mov ecx, [eax]
77f839d8: 668bc1 mov ax, cx
77f839db: 668944cf02 mov [edi+ecx*8+02], ax
77f839e0: f6460510 test [esi+05], 10
77f839e4: 0f85c2010000 jnz 77f83bac
77f839ea: 8b4510 mov eax, [ebp+10]
77f839ed: 8b00 mov eax, [eax]
77f839ef: 8d3cc6 lea edi, [esi+eax*8]
77f839f2: f6470501 test [edi+05], 01 <-- FAULT
77f839f6: 0f85b0010000 jnz 77f83bac
77f839fc: 0fb70f movzx ecx, word ptr [edi]
77f839ff: 03c8 add ecx, eax
77f83a01: 81f900fe0000 cmp ecx, 0000fe00
77f83a07: 0f879f010000 ja 77f83bac
77f83a0d: 807d1400 cmp byte ptr [ebp+14], 00
77f83a11: 0f84b0000000 jz 77f83ac7
77f83a17: 56 push esi
77f83a18: 53 push ebx
77f83a19: e85bf5ffff call 77f82f79
77f83a1e: 8b4608 mov eax, [esi+08]
77f83a21: 8b4e0c mov ecx, [esi+0c]
77f83a24: 3bc1 cmp eax, ecx
77f83a26: 8901 mov [ecx], eax
77f83a28: 894804 mov [eax+04], ecx
77f83a2b: 7521 jnz 77f83a4e
77f83a2d: 668b06 mov ax, [esi]
77f83a30: 663d8000 cmp ax, 0080
77f83a34: 7318 jnc 77f83a4e
77f83a36: 0fb7c8 movzx ecx, al
77f83a39: 8bc1 mov eax, ecx
77f83a3b: 83e107 and ecx, 07
77f83a3e: b201 mov dl, 01
77f83a40: c1e803 shr eax, 03
77f83a43: d2e2 shl dl, cl
77f83a45: 8d841858010000 lea eax, [eax+ebx+158]
77f83a4c: 3010 xor [eax], dl
77f83a4e: 8a4605 mov al, [esi+05]
77f83a51: a804 test al, 04
77f83a53: 746c jz 77f83ac1
77f83a55: a802 test al, 02
77f83a57: 0fb70e movzx ecx, word ptr [esi]
77f83a5a: 8d0ccd lea ecx, [ebp+ecx*8]
77f83a5d: f0 lock
77f83a5e: ff db ff
77f83a5f: ff db ff
Windows 5.1 (Windows XP build 2600) [Service Pack 1]
EAX = 0000ffd8
EBX = 012e0000
ECX = 0012fbac
EDX = 012e0001
EBP = 0012fb0c
DS:ESI = 0023:012e4880
ES:EDI = 0023:01364740
SS:ESP = 0023:0012fb00
CS:EIP = 001b:77f839f2
FS = 003b
GS = 0000
EFLAGS = 00010246
FPUCW = ffff027f
FPUTW = ffffffff
MM0 = b207a9b0b207add8
MM1 = 00000000b207ad64
MM2 = b207a9d0b207add8
MM3 = b207aa108057d529
MM4 = 000000000012f110
MM5 = 8000000000000000
MM6 = 9000000000000000
MM7 = 0000000000000000
Crash reason: Access Violation
Crash context:
An out-of-bounds memory access (access violation) occurred in module 'ntdll'.
Thread traces:
Thread 00000944 (Main thread)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\Init.cpp(321)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\Init.cpp(351)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\Init.cpp(369)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\VideoSource.cpp(617)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\VideoSource.cpp(645)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\Init.cpp(432)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\Main.cpp(307)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\Main.cpp(346)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\Init.cpp(442)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\Init.cpp(448)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\Init.cpp(454)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\Init.cpp(458)
Thread call stack:77f839f2: ntdll!RtlSizeHeap [77f50000+33316+6dc]
77f58cca: ntdll!RtlFreeHeap [77f50000+8a3e+28c]
77f59291: ntdll!RtlFreeHeap [77f50000+8a3e+853]
77f59037: ntdll!RtlFreeHeap [77f50000+8a3e+5f9]
012b4322: mpeg2dec3dg!closeVideo [01290000+10950+139d2]
0129b0b8: mpeg2dec3dg!?Close@CMPEG2Decoder@@QAEXXZ [01290000+af90+128]
0129c053: mpeg2dec3dg!?Copyoddeven@CMPEG2Decoder@@IAEXPAUYV1 2PICT@@00@Z [01290000+b9e0+673]
0129c008: mpeg2dec3dg!?Copyoddeven@CMPEG2Decoder@@IAEXPAUYV1 2PICT@@00@Z [01290000+b9e0+628]
00e51d19: avisynth!avs_create_script_environment [00e40000+10ae0+1239]
00e50e38: avisynth!avs_create_script_environment [00e40000+10ae0+358]
00e77dc7: avisynth!DllCanUnloadNow [00e40000+12020+25da7]
00e77d68: avisynth!DllCanUnloadNow [00e40000+12020+25d48]
00e80e87: avisynth!DllCanUnloadNow [00e40000+12020+2ee67]
00e80e28: avisynth!DllCanUnloadNow [00e40000+12020+2ee08]
00e410d8: avisynth!000010d8
00e4c55a: avisynth!0000c55a
00e4c488: avisynth!0000c488
00e52605: avisynth!DllCanUnloadNow [00e40000+12020+5e5]
00e523da: avisynth!DllCanUnloadNow [00e40000+12020+3ba]
73b552d5: AVIFIL32!AVIFileRelease [73b50000+52cb+a]
004165a1: AVIReadHandler::_destruct()
004146df: AVIReadHandler::~AVIReadHandler()
0041669d: AVIReadHandler::Release()
00485ef9: InputFileAVI::~InputFileAVI()
004876fa: InputFileAVI:special)()
0046c6f0: CloseAVI()
00484de7: Deinit()
0048bd6d: WinMain@16()
77f8e3c3: ntdll!RtlReAllocateHeap [77f50000+3d648+d7b]
005519dc: realloc()
77f59baa: ntdll!RtlAcquirePebLock [77f50000+9b82+28]
77f59bb3: ntdll!RtlAcquirePebLock [77f50000+9b82+31]
77f59bf9: ntdll!RtlReleasePebLock [77f50000+9bea+f]
77e61a57: kernel32!GetStartupInfoA [77e60000+177e+2d9]
00551bba: WinMainCRTStartup()
77e814c7: kernel32!GetCurrentDirectoryW [77e60000+21483+44]
-- End of report
Foxconn A79A-S|AMD Phenom 9950 BE|8GB RAM|150GB WD Velociraptor|2 HD4850 in Crossfire|Windows Vista 64 Ultimate SP1
Abit NF7-S|AMD Barton 2500|1GB RAM|3*160GB HD|HD3850|Windows XP Pro SP3 -
I think I have found the source of the problem. I think that some sick **** (hacker) had access to my media library and messed it up, replaced some VOB files with VOB from other movies or made some VOB files totally unaccessibile. When VirtualDub tried to access these unaccessable files it crashed. Why people do such nasty things? May be because they are ugly and have complexes that do not even allow them to have a girlfriend, like normal people do...
ColorTools 1.4 crashes Virtualdub
By LSchafroth in forum RestorationReplies: 10Last Post: 26th Apr 2013, 09:28 -
VirtualDub crashes when using MSU Subtitle Remover :(
By ralf07 in forum SubtitleReplies: 1Last Post: 17th Mar 2012, 03:16 -
Olympus camera memory card crashes virtualdub
By snafubaby in forum Newbie / General discussionsReplies: 4Last Post: 1st May 2011, 01:08 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 14:26 -
Virtualdub crashes
By Kevlin in forum EditingReplies: 2Last Post: 18th Jan 2008, 23:01
special)()
