    May 2004
    WA state USA
    when capturing dvd format, should i capture 48 or 96 hertz?
    i use the adugiy2 zs
  2. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    48 is standard.
    May 2004
    WA state USA
    but would 96 be better?
  4. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    To make a compliant DVD select 48. That selection is even greyed out if I choose to make a compliant DVD. If you select something eles most likley somwwhere along the line it's going to get changed to 48, if it isn't there's a good chance it won't play. I'm no expert in sound but increasing the KHZ to 96 isn't going to increase sound quality if your source is 48 or below.
