Hello everybody, I have recentley obtained a mass of (original) NTSC DVD movies as gifts from over seas. I Live in europe and my setup(s) will only allow me to play PAL dvds!!!. I am reletivley new @ this but i do have basic knowledge of DVDdecrypter,Shrink,Tmpgenc author etc. What i would like to do is convert the NTSC dvds to PAL dvdrs with little quality loss (movie only). I have searched the forums but i cant find a solution.
p.s. I have converted one of the films to vcd pal but the quality is not good enough.
Many thanks in advance to NE 1 who can help!.![]()
Thanks For Coming!
Are you actually sure that you need to do this? I ask because most DVD players and TV's in Europe are multiformat and will work with PAL and NTSC discs. Have you actually tried playing them, if not give it a go and you may get a pleasant surprise with what happens.
Artificial intelligence is no match for natural stupidity. -
I have tried but im afraid it doesn't work on either of my setups. my only option is to convert . thanks all the same
Thanks For Coming! -
I think you are wrong.
I do this on a regular basis.
The issue is not the dvd-player but the television set.
The television set must be able to do PAL-60. Otherwise you will get no picture or a black/white picture.
Use the SCART connector. It has component connection as well. You can get adaptors for that.
Otherwise the only way forward is a total recode through virtualdup and tmpenc.
Good luck -
TMPGenc Xpress 3.0 will encode directly from vob files. That may cut out a step if you have to re-encode.
Look, let me explain something. I'm not Mr. Lebowski; you're Mr. Lebowski. I'm the Dude. So that's what you call me. That, or Duder. His Dudeness. Or El Duderino, if, you know, you're not into the whole brevity thing--
PAl to NTSC dvd projects - Conversion
By bpinto0805 in forum Newbie / General discussionsReplies: 1Last Post: 31st May 2009, 02:10 -
PAL DVD to NTSC Conversion (read as much as I could)
By DW in forum Video ConversionReplies: 3Last Post: 27th May 2008, 02:42 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19 -
PAL to NTSC DVD Conversion Problem
By squallx404 in forum Newbie / General discussionsReplies: 4Last Post: 8th Oct 2007, 05:16
