I can't seem to find a guide on this or anything in the forums. Can anyone tell me what tool(s) are needed please and a little guideThanks
I've never really done this type of conversion before (don't have many svcd's with video that is not on my pc). Anyways, I looked in the Tools section with conversion - SVCD to DivX. It brought up many applications that you may want to try out. Also, Virtualdub-MPEG2 may be able to do the trick. Import the svcd file into VirtualDub-MPEG2 and then export it setting the compression to DivX. Hope this helps!
rip the mpeg-2 from the SVCD using isofilter. After that load the mpeg-2 into virtual dub. Select a compression codec and then save.
Brilliant cheers, Virtualdub mpeg2 did the job perfectly. I must of missed it when i was looking through the guides. Thanks again
Converting 16:9 DV-AVI to Divx/XVid, its always horizontally squashed...
By mjvgiese in forum Video ConversionReplies: 2Last Post: 20th Jan 2010, 22:18 -
Converting DVD to AVI...but to DivX, MPEG4, YUV or XVid??
By lnong in forum DVD RippingReplies: 1Last Post: 11th Oct 2009, 07:44 -
Converting AVI (DivX/XviD) to MP4/MOV/3GP...
By JaleAlbatros in forum Video ConversionReplies: 5Last Post: 23rd Jul 2009, 18:51 -
Converting VBR avi Xvid/divX to wmv9
By surfmonkee in forum Portable VideoReplies: 4Last Post: 17th Nov 2008, 03:54 -
Converting ISO to AVI (Divx or Xvid)
By cyberjackal in forum Video ConversionReplies: 2Last Post: 11th Jul 2007, 11:50
